Looking to replace my stock hardtop with a soft top option, I've looked in Amazon but since I am no expert I would like some guidance..
I have a 2012 Jeep Wrangler 2 dr... So far I've narrowed it down to these options, don't like the square look for a softop, also would it be possible to ride with a soft top in all weather conditions? I know some jeeps do have them but I don't know the performance factor againts cold weather conditions...
I would like the ability to take the tops off enjoy and when the weather gets bad or rains, be protected. Recommendations would be greatly appreciated...
Amazon.com: Bestop® 56822-35 Black Diamond Trektop NX Complete Frameless Replacement Soft Top with Sunrider® Sunroof Feature: Automotive
http://www.amazon.com/dp/B00FB0UZDG/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=2FDYLXCLK92TX&coliid=IVFJNU65Y28YE
That first option you linked to seems to be a very popular choice. I've heard the installation can be a little hard, but there is a video tutorial that should help, and the key is to let the fabric sit in the Sun for a while and relax.
I have a hard top on my JKU, but from what I've read elsewhere, the soft top shouldn't be a problem to use year-round as long as it's installed properly and maintained. Except for the worst rainstorms, you shouldn't have to worry too much about it leaking water, and they do a good enough job of retaining heat. Biggest issues with the soft top is they are less secure than a hard top, since anyone could walk up and take down the windows, cut through the windows, etc. and the fact they are noisier than the hard tops.
Not sure about pavement ends, but I had a trektop NX on my 2-door for a while. I had to modify it a bit to keep it from flapping on the highway (stronger rear bar across roll bars), but after that, I loved it. Note that neither of these tops are easy to completely remove or roll back like the regular soft top. The windows come off and leave you with a very nice safari top. I ran mine all summer long with no doors and just safari top. Pulled carpets, got waterproof seat covers (iggee), and let it fly. It was awesome!
I had a 97TJ many years ago. I replaced the top with a Best Top "Sail-Cloth" version. The wind noise reduced noticeably. It also had a tinted rear windo option which helped with heat in the summer. Never had an issue with leaks from the factory soft top or the Best Top replacement.
