Sorry if this is already a thread, but does anyone have any experience/suggestions to share about touching-up the paint on their hard-top?
I have a few minor areas I would like to hit up on mine. Thanks in advance...
Rustoleum semi-gloss black. The color is spot-on and the finish is pretty close. Wash and clean the area first (and rubbing alcohol is a good second material to apply). I also use this paint on rust patrol for the suspension and undercarriage on an annual basis.
If your top is black the color code will be PX8. If it's body matched You'll need to get the color code from your door jamb before you order.
Here is where I get my touch up paint. www.TouchUpDirect.com
(I recommend a touch up jar for most small jobs)
2017 JKU Hard Rock
^The mopar hard top paint works great and should be an easy pickup at any dealer. I've been using it for years!
On a side note, it's also a pretty damn good match for AEV Saltas in matte black. I've used it to touch up rock rash on mine and it blends perfectly!
