My friend just ordered a hard top for her 2008 wrangler unlimited, she got the wire kit to go along with it. Was there anything else needed? (Window channel?)And how easy is installing the hard top?
Build Thread Queen
Not sure if it comes with the wiring kit or not, but she will also need a new stalk for the steering wheel with the controls on it.
She will also need to have her computer flashed so that the jeep knows that the new stalk is there, I believe.
Installing the hard top itself is pretty easy. That shouldn't be a problem at all, as long as you have enough people to lift it.
If you can get it in position (a helper or a lift), installing it is pretty simple -- 8 bolts, and plug in the wire and washer hose.
I believe the wiring kit does not include the HVAC control. The dealership will charge about 2 hours labor to install the wiring kit.
The top itself is very easy to install.
Great thanks for the advice, the hard top just attaches straight to the factory wind shield?
