so my switch for my hardtops wiper works perfectly fine... wondering if anyone knew about the defroster? I would assume when turned to the 'on' position a light would illuminate.. but nothing. and of course after about 15 mins, still foggy. I just wanted to ask around before i start checking fuses (where i assume i should start of course)
Help?
there is a red relay on the bulkhead by your left leg. it is a time delay relay. it takes power off so that the defroster does not stay on too long. does the switch light ever come on? just for a second?
the indicator light on the switch itself has never come on when i try to use it...
and i have located the relay u mentioned.. should i try and replace relay?
tap on it..gently....it may be just a stuck contact. what year is your jeep? under the hood check fuse(50a) 3, fuse block by steering column, fuses 6 and 9.
Yeah please let us know. i am in the proccess of wiring my up and this would be something i might have to check as well.
