Hey Gang
Yes/No. Will the hardtop on a '99 TJ interchange onto a '05-'06 TJ?
My current Wrangler is '99 4.0L/5-spd.
It is suffering terminal frame rot to the point the rear upper control arm mounts have failed and the upper control mounts have rotted off the rear axle.
I'm going Monday to look at a '06 4.0L/6-spd. with 77k miles and multiple upgrades but its a soft top.
Thanks for your advice.
Jonathan.....
Hey Gang
It is suffering terminal frame rot to the point the rear upper control arm mounts have failed and the upper control mounts have rotted off the rear axle. Only downside is the harness plugs are not compatible.
Jonathan.....
The top will fit and there are numerous in service with that arrangement.
The only difference is the top has relief vents on each side behind the window and after 02 the vent was relocated to the tailgate. You will just have extra venting. The only downside is the harness plugs are not compatible.
