Picked some up off CL today. Hardware not included. Nut size for the pinch seam anyone? Body bolt size as well? Do I need washers?Greatly appreciate some help!
The nut size was 10mm. They used washers. I do not remember if it was fine or course though. The body bolts were 18mm. You will use the ones already under the jeep.
For a 2DR, 2007-2011:
(4) BOLT AND WASHER, Hex Head, M8X1.25X25.00
(4) U-NUT, M8x1.25
(8) NUT AND WASHER, Hex, M6X1.00
For the Unlimited its:
(6) BOLT AND WASHER, Hex Head, M8X1.25X25.00
(6) U-NUT, M8x1.25
(12) NUT AND WASHER, Hex, M6X1.00
I also found that you need oversized washers for the smaller M6x1.00 bolts as some of the body holes are kind of big. If you have a 2012+, you dont need the U-Nuts, as the holes in the body are threaded (they are covered by tape and some silicon....but they are already threaded)..
