you bypassed the broken connector/wire on / behind the fuse block... good idea...
but if you can handle putting on a spade connector, then you could pull the fuse block off and look behind/on the side of it and find the broken wire/connector...
Im guessing it is broken but probably a connector that kinda slipped out or has some corrosion in it??
but I like your write up... a picture would be awesome...
