1 - 9 of 9 Posts
Looking for opinions here. Got an Odyssey battery on the way. I don't run a bunch of lights, stock stereo, and don't plan on doing heavy winching. Is the Odyssey battery with OEM alternator sufficient? Or is upgrading the alternator worthwhile in addition to the battery? TIA
No reason to upgrade as the standard alternator will handle your application just fine. As for the Odyssey battery it requires no more power to maintain than any flooded or AGM battery, All the battery does is start the engine or provide power when engine is off or ruining to slow for the alternator to pick up the load. As for winching you would be better served with a battery that has fewer cranking amps and more reserve capacity.
Appreciate it. That was my thought but wanted opinions. I rarely run anything with the engine shut off, but was curious if the hd alternator would take the load off the battery and electrical system and avoid other potential problems.
The stock alternator is pretty strong, from my sample of one, and you rarely read of failures. I certainly didn't consider upgrading when I bought my Odyssey, and it's been fine. I put the battery on an Odyssey charger occasionally in the winter, when the jeeps sits for long periods, but that's it.
Mark
Sent from my SM-G935V using Tapatalk
Reactions: SPI Wrangler
Out of curiosity, what aftermarket options are there for installing a heavier duty alternator in a Wrangler?
Mean Green and Tuff Stuff both make larger alternators, 200 amp, 250 amp vs the 160 amp stock version. Those are just the 2 I know off the top of my head.
Appreciate the replies. Looks like I will stick with OEM alternator and free up the funds for other upgrades. Thanks again.
I did a bunch of research on this and just went stock when it was all said and done. Turns out my low voltage reading on my gauge was due to a faulty battery connection. 99% sure the old alternator was ok. If not needing to replace just stick with what you have.
1 - 9 of 9 Posts
