1 - 15 of 15 Posts
Noticed my head and taillights won't come on last night got home from work and my battery was dead, jumped it and now my wipers nor lights work any suggestions?
If you fill out your profile that might help. My head light switch is on the dash on my 00, on my 04 it is on the stalk/multi switch. Which do you have?
I checked a few but the description isn't great on the fuse box. Would a fuse cause wipers and head/tail lights not to work?
Just get an ohm meter or continuity tester out and check all the fuses. If it is a fuse, you'll find it.
Discussion Starter #7
Failed to mention that my clock spring has been bad for awhile so I'm going to start by replacing it
He only has 29 posts. Maybe this was a hit and run! :p
Discussion Starter #13
Easy fellas. Sorry but the solved post was for the dead battery. As for the issue I'm having I have a clock spring problem my airbag light has been blinking for a month or so plus my horn hasn't worked in awhile. If you look at a print it all ties in together and I'm hoping the multi switch gets its feed from the clock spring so I bought it yesterday going to install Saturday. Fwi I paid 250 at dealership (yea I know I could have got it cheaper online) but I heard mopar beefed up the spring so I guess time will tell. If not I guess I'll buy a new multi switch.
That is awesome! I just had my dashboard out a little over a month ago so I got to see the inner workings of the clockspring. Glad to hear that all is working now.
1 - 15 of 15 Posts
