Anyone know of a way to program the radio to a lower volume when restarting the jeep, or to "normalize" the volume levels between input sources? Or perhaps even choose a default startup input (like the CD player if the Aux isn't an option). Here's my problem. I listen to a lot of bluetooth streaming from my phone. I get to my location and leave the vehicle and when I restart the vehicle, it reverts to the radio which is WAY louder than the bluetooth level. If I remote start my car, I can hear the radio blaring away. I try to remember to turn it down before turning off the jeep but would love another solution. Any ideas?
There is no way to do what you are asking.
Best solution, lower the volume before turning the vehicle off.
Or turn up your Bluetooth volume? My S5 makes me manually dismiss an idiot warning, but then I can turn it up louder.
New head unit will take care of that..
I had a similar problem - my Bluetooth level was 1/4 of the radio or CD.. My new 4100NEX lets me set the level for each input.
When my Bluetooth doesn't connect, the radio reverts back to the last source before the Bluetooth was used. So I use the built in hard drive that has my mp3s on it, then change to the Bluetooth (iPhone Pandora). If my iPhone does not connect, I don't get some obnoxious radio station trash. Try using your CD then Bluetooth and see if that helps.
I'm almost always streaming bluetooth audio too, and know exactly how you feel. The only solution I have found is to use an aux cord. Connecting and disconnecting the cord upon entry and exit is probably worse. I guess another reason (or excuse) to ditch the horrible stock headunit.
You could also turn up all the equalizer bands on your Bluetooth device, making it louder, to better match your other sources.
