Is there a good solid solution out there that I am unaware of......my Passenger side headlight bucket is all screwed up :atomic: and am trying hard to get a proper lock in my headlight aiming.....:banghead:
some links of videos or product link would be helpful....any information is helpful...
Sandan
I am not sure I follow...
There is a screw (torx) to adjust up and down, screw it in for down and out for up as I recall. The stud for side to side can be replaced with a screw tha allows you two axis of adjustment, otherwise you likely only get the one.
If the headlight bucket is broken you may need to fix that first.
both axis can be adjusted
the torx screw adjusts up and down.
this can be easily done no disassembly with a torx screw driver .
to adjust side to side you have to remove the grill and headlight
inside the housing there are 2 plastic 13mm?? nut adjustment screw pins left and rt
this is the part that many replace with a new torx screw.
there isn't much room inside the headlight bucket but you can use a wrench to make adjustments without replacing it .
screw out the side that will push the beam in the direction you want
its a pita because you get only like 1/4 turn per wrench bite,and you need to reinstall the headlamp to check aim.
thanks for all the info, my passenger side bucket is popped out of the screw head from one end and i think 2 of the trox screws thread are no longer holding.... ordering that bucket today hopefully that will fix it....
sandan
Discussion Starter #6
so I have these 2 parts in my cart on amazon....just planning to have all parts before I dive into this..
https://smile.amazon.com/gp/product/B00V40JPVA/ref=ox_sc_act_title_1?smid=A27HP35N2ID31P&psc=1
and
https://smile.amazon.com/gp/product/B007O3AN26/ref=ox_sc_act_title_2?smid=A1T4TLQPKV602J&psc=1
How many of each will I need per side... And whatis the function of the pivot stud....just trying to figure out the setup....can someone direct me to a detailed breakdown of how exactly the headlight adjustment system works on our jeeps...
Sandan
Discussion Starter #8
ok will do......I have ordered the above 2 parts and will be deep diving into fixing the headlight and will post some pics...
sandan
