Can anyone recommend a brighter replacement bulb? PIAA?
Going in to the stock housing, it will be the Philips XTreme Power +80 H13 lamp.
But the H13 and stock housing is pretty weak. Consider doing an H4 conversion for a noticeable improvement.
Yeah the Phillips is not much better than stock. I was not impressed at all.
Op, here's stock:
Phillips X-treme Power +80:
Swapped my stockers for H4 Cibies, ordered the KC Lites H13 to H4 headlight conversion cable and went with Philips X-tremevision + 130.
Is it better than what's stock - yes. Are you going to be blow away - probably not. But again, for a relatively inexpensive cost, you can get some decent lighting. The light output that I have now is what I believe should be stock.
The Phillips Xtreme are plug and play. It's a good basic upgrade. I have them in my JK almost 6 years with no problems. Unlike some other bulbs, they last.
