I got the Hella E-Codes with Hella 55watt/100 watt bulbs.Installed with relays, their great! The light housing lens is glass,which i wanted,plastic ones will scratch.Check your voltage on stock headlight harness,mine was 11.2, with relays added with 12ga. wire it is 12.4 volts. Your lights will be brighter its easy to do,there are diagrams,if you search online.
