Getting ready to do headlight replacements on 2013 Wrangler Unlimited.
Does the grill need to come off to do this? Looks like it might.
If so, what's the best method to remove the grill?
Thanks
Pop those black plastic rivets along the top of grill and it will lean forward. Allowing you to work on head lights.
There are clips on the bottom too that come out easily by pulling the grill away from the Jeep after you remove the top row. You just have to remove the turn signal markers if you are going to fully remove the grill by twisting them 90 degrees.
This is for a 2012, should be exactly the same for a 13'.
