Headlights
4520 Views 48 Replies 34 Participants Last post by  sok
New to the whole jeep thing. Just bought my first jeep. 06 tj. Love it, everything but the headlights. Can I just by better bulbs or what? Installed a light bar and wow! But as far as general highway driving- I can hardly see! What to do??
1 - 20 of 49 Posts
OEM headlights are just slightly better than candles. If you have the OEM setup, it is a sealed beam so you cannot put a bulb into it. You have options:
low dollar: ~$45 - SYLVANIA H6024ST SilverStar sealed beams
mid dollar: ~$170 - Hella e-code H4 conversion with bulbs
high dollar: ~$350 - Truck-lite LEDs
Try out trucklite LED headlights. The problem with cheap alternatives is the housings are crap. You can have the brightest light in the world but whats the use if the housing cant project it properly. The trucklites are around $330 a pair, use less power then one OEM TJ headlight, the low beam and high beam is super bright and it has a nice straight cuttoff. The TJ headlights kind of just threw light out in front of you in no real pattern. Trucklites have lights thrown out about 160 degrees In front of you, and it is consistent until the cutoff. People complain about the price but look at it this way. Half of our day is dark and we use our headlights, why go for something that sorta works when you can buy something once that will work amazing.
I was hesitant to drop ~$300 on the Truck Lites. I was worried that yeah they are brighter, but they still suck. Finally pulled the trigger, install took just a few minutes. Flipped them on and was not impressed (of course it was the middle of the day). When it got dark, finally took her out for a spin and WOW these things are fantastic. These are definitely worth the cash.
One concern I had was ice build up in the winter, I drove with them through the winter and never had a single problem.
I upgraded to the Sylvania 6024 Silverstars referenced above and it made a night and day difference (stockers were junk). You can buy a set of them off Amazon for ~$40 if I recall correctly. I also changed out my factory foglight bulbs to silverstars because the stockers were so yellow after replacing my headlights. I would recommend the Sylvanias.
1 - 20 of 49 Posts
