1 - 10 of 10 Posts
Cap probably cracked from wear or lack of grease, split into a bunch of pieces, and fell out. How many miles on the jeep?
I changed the u joint like 6 months ago .. I don't think I have added grease since then.. so you may be right.. I was surprised that it will only last 6 months.. unless the replacement I used was a very crappy one..
Yeah, must have been a bad quality one or it dried out and seized. Go with a Spicer ujoint if you can
found the only universal U joint left in Nicaragua with the specs I needed!!!
Jeep is back!!
I'm going to look for the Spider one that was mentioned and have it there just in case this happens again..
Cheers!
Knows a couple things...
Do you have any vibrations from your 2" suspension lift? Drivetrain vibrations can and will cause u-joints to fail prematurely.
And the part number for the Spicer u-joint that is appropriate for your driveshaft is 5-1310x.
I didn't really have any vibration that I noticed.. one day the u joint just fall into million pieces after a 300 miles ride... we replaced the u joint with a stock one and now this happened.. I saw that one of the "clamps" was showing too much wear.. I think the cap of the ujoint just snap through it, making it lose..
I will be checking the u joint in a regular basis now.. I didn't know it needed to have grease all the time (big mistake) so lesson learned..
thanks for the data for the ujoint!
1 - 10 of 10 Posts
