I used to street race before crossing over to the 4x4 world. I know in the race world we used to heat wrap our header to keep engine bay temps down for a cooler air intake.
My question is that since the intake manifold and the exhaust header are pretty much interwoven ( this is on the I 6 motor )between each other. Do you loose power since the intake is "warmer" air? Should you heat wrap the header to keep engine bay temps down and to provide for a cooler air intake?
That's a good question, if you have stock manifold cast iron or tubular header kind, they restrict some flow and hold a lot of heat which in returns cause them to crack, I've had mine of twice once to replace the gasket and then when I put a real header on it. This is a pain in the whole body job to do so if its not leaking leave it alone until it does and then wrap the replacement one
Bumpidy bump
I'm sure it wouldn't hurt except making them crack faster, I don't think rust is an issue with the factory ones. maybe just make up a piece if aluminum for the bottom of the intake to shield heat. I noticed my intake temp is 126° when I pulled it up on the scanner when warmed up. And your computer will compensate for whatever your air intake temp is reading.
I could see the comp changing based on temp but cooler air is more dense. So I would give you the extra ponies you may need. Why would they crack faster?
They are already prone to cracking, and if you're ever wrapped headers before and kept them, they rot away alot faster and it also voids the warranty.
Correct, on a street vehicle that will see wet weather, the wrap will stay damp for long and hold moisture and cause the metal to rot faster.
I plan to put some kind of heat shield on mine between the header and intake manifold to keep the intake air temps down. Since i don't plan to wrap my header, I have been looking into hood louvers like poison spyder and gen right off road to keep my underhood temps lower. I just like the idea of the heat sheild better because I am not sure how header wrap may affect the strength of my header.
