1 - 20 of 27 Posts
I had a similar set up in mine they worked really well untill the first time they got wet. Then they were kaput ! So if you make sure your top is up every rain shower. And every heavy dew. Then you should be fine
I have a set of carbon fiber heated seat covers that worked very well. Now that I am out of work and do not need to leave at 6:30 am I may not need them for a while.
Knows a couple things...
Man I would love me some heated seats. I made the mistake of taking off for a winter desert wheeling trip without my top and took a shortcut oover the top of my local mountains where I drove through a bad snowstom with howling winds. I don't think I have ever been so cold in my life. :eek:
call me cheap, but i think im gonna take some $15 heat pads from Wal-Mart and sew them into my cheap junk seat covers. then plug them into my power inverter. total cost $50 inverter was a $20 yard sale special.
Once you use them you will say, what was I waiting for?
A 120v home heating pad draws more power than you think which means it'll require a much bigger inverter than you may have or be expecting. Any type of electric heater draws a lot of power. If your inverter can't provide at least 1500 watts continuously, I wouldn't do it... and most inexpensive inverters can only handle 300-800 watts. Not to mention that when talking amperes, that heating pad will draw well over (because the inverter is not 100% efficient) 10X as many amps at 12v than it does at 120v. So if for example it draws 5 amps when plugged into 120v, it'll draw well over 50 amps out of your Jeep's 12v system. When there is 1/10th the voltage (120v vs. 12v) to work with, it requires 10X the amperes to provide the same power.
Full Size Jeep Dr.
Heated seats are one of my planned upgrades. I may have to jump on this!
its a 2000 watt inverter with 4 120v plugs. and ima be putting in dual batteries before I do.
I had those in my original seats, then moved them to my PRP seats.
Cheap and easy to install. I've had them for a couple years now, soooo nice.
That's a real bad idea. 120v AC is enough voltage to kill you if it gets wet, or to start an upholstery fire with an arc from a short circuit.
Use the 12v seat heater kits, they are lots safer.
Yep in spite of the availability of a 2000 watt inverter, as an electrical kind of guy, I would only consider 12v seat heaters. I wouldn't give 120vac seat heaters even a passing thought for a Jeep.
yep in spite of the availability of a 2000 watt inverter, as an electrical kind of guy, i would only consider 12v seat heaters. I wouldn't give 120vac seat heaters even a passing thought for a jeep.
x2
I used to drive a '69 VW microbus all year and you probably all know about the factory heat in those. Never got above 40-50 F if it was below 20 degrees outside. Got some heated seat covers that plugged into the cigarette lighter with a thermostate switch and everything. Man, that was nice and toasty. I wish I'd kept them when I traded it for the Jeep. May have to get me some of those for that price! Thanks man!
Agree 100% I live in Oregon where I get in my rig most of the time soaked with rain from hunting/wheelin. You guys can have your ass and balls sitting atop a 120 ac grid all you want without proper grounds. Have fun with that!
I installed the Dorman Kits in My TJ & My Wife's Expedition Last December so far they have worked Great the one's in the Jeep have got wet a time or 2 & still work just fine, Kits were around $60 per seat on eBay.
1 - 20 of 27 Posts
