Last night the heater fan stopped. I can hear the diverters or baffles moving then I switch the output positions (head or feet) but there is no blower. I checked two fuses and both are intact :
j15 40amp front blower
m15 20amp climate control system
I am thinking it may be the fan switch itself. Anyone have any ideas?
no, I've got to figure out how to take apart the dash, and find the fan. behind the glove box?
Discussion Starter #6
Unplugged the fan.
Metered the power going in: it was there and changed when I turned the fan speed knob.
Pulled the fan. really easy to do, 3 torx screws.
Hooked it up to 12v dc power and it spun.
Plugged it back into the harness and it worked.
Assumed the connector plug (although it seemed tight) got kicked loose.
I have heat, now, again.
Thanks Klaxler
