· Knows a couple things...
There are two potential reasons a fan will only work on the high speed setting. Either the fan switch is bad, or the resistor pack that the fan switch selects the speeds from is bad. The resistor pack is the most common cause, it's located above the passenger side footwell and it can easily be replaced.
