Can't seem to get any idle heat out of my 08 unlimited. I replaced thermostat and back flushed the heater core.. It'll start to over heat until I get moving above 50 mph.. Then the temp will drop back to normal .. Then I'll get heat till I stop moving .. Help???
Could be a couple things that are causing this. You might have air in the system or you might have a worn water pump. We just had a caravan in the shop with a similar problem. The pump looked fine on the outside but once we pulled it there were only two blades left on the impeller.
You might be able to see if the coolant is circulating at an idle if you look in the radiator. This may or may not be accurate.
