Here's my problem, (or at least one of them:)), my heater has defaulted to defrost only, which I think I've narrowed down to the vacuum hose actuator that powers(?) the blend door. The problem is, the hose is gone and I can't figure out where the new one goes! I believe the connection is on the firewall below the battery and toward the engine, about a 3/4 inch connect, am I right? Where does it connect to from there? This is probably a common simple problem, but I'm at a loss!:facepalm:
Also, my cruise stopped working, the light comes on but no action. I think it's the servo, any ideas? Thanks
▄▌ee▐▀
Follow this diagram an figure out where it is disconnected
Usually the connection at number 2 falls off the nipple at number 5 right below the throttle body.
If its connected then you should check were the line plugs in to the box labeled number 8 as battery corrosion can eat away the end of the tubing. Easy way to find number 8 is to lay under the passenger side of the Jeep and look up along the firewall as that box is in an opening in the frame right below the battery
