Ones the hood scoop really help your heater or is it just for looks? And is the anything to help heat the inside better besides just your feet?
hood scoop is for looks IMO.Ones the hood scoop really help your heater or is it just for looks? And is the anything to help heat the inside better besides just your feet?
I do get air some air movement whether the fan is on or not.I don't even need to turn my heater on, it blows hot air all the time. Is that normal?
Yes, I feel resistance with the lever, and I can hear the baffle opening and closing. When I move it to Vent, the blower motor comes on, is that normal?I do get air some air movement whether the fan is on or not. But the temperature lever should control the heat. As you slide the lever from Hot to Cold you should feel resistance as the attached cable open and shuts the baffle.
No, the fan motor is supposed to be inoperable in both the 'Off' & 'Vent' settings.... When I move it to Vent, the blower motor comes on, is that normal?
Ok thanks. Sorry for highjacking the thread.No, the fan motor is supposed to be inoperable in both the 'Off' & 'Vent' settings.
