It looks really clean.Hello all. First post and looking for some insightful knowledge. My past has been in the world of broncos and most recently an FJ Cruiser that I just passed on to my daughter. Looking for another 4x4 and really want to give a Wrangler a go. I have been researching and had two in mind. One is a 08 sahara with 124k but looks to be in really nice shape and priced well. the other is an 04 sahara, also appears to be in good condition. I've read too much on the 3.8 and it has me turned off from the 08. I would like to get y'alls input on this TJ 04 sahara I will be going to look at it in a day or two. Any info I can gather on the TJ and this particular one would be greatly appreciated.
Definitely check for rust and oil leaks.
Rear main seal is a common problem on the 4.0's causing it to leak oil.
Not really an expensive fix so don't be turned off by that.
Looks like there is some type of lift on it along with possible 33" tires?
Try and find out what type/brand lift is on it and take it on a test drive over 60mph.
Check for vibrations and front end wobbles.
If all checks out, I would pull the trigger
