So I got the LED's installed but I am having a few problems.
#1 - Occasionally the "resistors" don't seem to work and the Jeep says Right/Left Light out, then that signal blinks really fast. I can seem to resolve this one, but the second one is my major issue.
#2 - When I use my turn signals, both right and left signals turn on.
So what happens is if I signal turn left, the left signal flashes as normal but the right signal is flashing also, but dimmer and in alternate sequence.
I am hoping someone can give me some guidance as I tried everything I could think of. I even used both harnesses, put one old taillight back on (it doesn't happen then). Although as we know, I cant actually put my old lights back on anymore, since I had to grind the mounting areas off.
Thanks,
John Petrilli
Discussion Starter #2
Any ideas? I made sure the resistors match in terms of flow. There is no neg or pos indicators but it didn't do anything. Helpful.
Thanks,
John
Have you tried contacting Rockridge....?
There may be an issue with one of the LED units...
I sent them an email, but didn't last night but didn't get a response yet. So I was just seeking some help on here if maybe someone knew something.
Ok Jeff at rockridge4wd is amazing. He was able to help me fix what I was doing wrong.
I had the resistors installed incorrectly.
Thanks again to Jeff at rockridge4wd.
For anyone else who has a similar issue I have attached the wiring diagram for the resistors.
:iamhappy:
- John
