I am planning on putting a 3.5-4.0 inch lift on my 15 JKU. I would like to run 35s on this when the lift is complete. I would like to use my factory wheels if possible, but I am not sure if i can after reading some threads that stated i would need spacers. So assume a 3.5 lift and 35s with factory wheels? Would it work or no? Also, if the answer is no, how do i know what size spacing i would need from the aftermarket rims that i order? Thanks in advance.
Tire & Wheel Specialists
Hi, Ty-
Tire size 315/70R-17 (35x12.50 metric equivalent) fits the factory 17x7.5 wheels, but the backspace/offset is too high which will cause the tires to rub suspension components. You can use 1.5-inch wheel spacers to push the assemblies outwards, however new wheels with proper backspacing/offset is considered the safer alternative (one less link in the chain that can fail so to speak).
If you decide new aftermarket wheels are best for you, a 17-inch wheel with 4.5-inches of backspace is most common. Here's the link to browse Discount Tire Directs 17-inch JK wheel selection. If you have any questions feel free to shoot us a PM, we're here to help :thumb:
17-inch JK Wheel Options | Discount Tire Direct
Reactions: Discount Tire
@tynorris2340 don't let me insult your intelligence. Spacers just "sit" on top of your coil springs and below the place where the spring would sit on the frame. It *is* possible for enough droop to cause the spacer to fall out. What @Discount Tire said about new wheels makes more sense and is safer than spacers.
