Hey I hope you guys can help. I have a 2014 Jeep Wrangler Unlimited which I just installed a 2.5 lift on about a month ago, and just installed 35 inch tires about two days ago. Ever since installing the tires I get a clunking noise whenever I drive every 15 seconds or so. It doesn't matter if I drive straight or if I turn there's still a noise. it sounds like it's coming from the front driver side but I can't be completely sure. Anyone have any idea on what this noise can be?
Also check your lug nuts, if a wheel is loose enough it will clunk at low speed and vibrate the faster you go.
