1 - 20 of 25 Posts
Oh please help me! My YJ's doors wont come off. I have removed the nut, cleaned the area with wd-40, let dry. I then sprayed a liquid wrench type of lubricant, (not wd-40), and swung the door back and forth for a while...
Lifted straight up and the whole jeep rocked, but alas the door is still on...
Any Suggestions?:banghead:
Rubber mallet!!!
and maybe some PB blaster. also, while you're lifting up, rock the door in and out--it helps....
lemme know if you still cant get them out..
uh.........are you saying you heated up and sawed your doors off?
are you a caveman???
lol
tried the mallet too, now i have a bit of a dent, maybe i swung too hard? OOPS I was really frustrated.
you dented a steel door with a rubber mallet??? :eek::eek:
how is that even possible
Discussion Starter #7
lol
NO NO NO i was saying these are tool i will not use to do this
i am wearing a superman shirt...LOL
Really though, it's small more like persuaded the steel in the direction of my mallet...
if a full door, open the window push up with your arms or back and lift wtih your legs. some hinges have a nylon spacer in them. if yours do, do not lose them.
Think back to physics class. Put a 2x4, shovel handle, crowbar under the door and over the door sill with the door open about a foot and lift (lever and fulcrum, remember?) and the door should pop right up. Just put the lever as close to the hinge side of the door as possible.
The rubber mallet should only be used on the feder if you drop the door on your foot.
I agree with copleydad, but grab someone to help you, should the door actually pop out.. remember, you are wearing your Superman shirt
and hopefully steel toed shoes.
after birthday glow
soak the thing in pb blaster or wd 40 worked on mine no prob also make sure the nut is not on the bottom of the top hinge i'v seen this done dont know why but they thought it was a good idea so who knows
Discussion Starter #17
This worked^:D
Thanks to everyone who chimed in to help!:punk:
while I was at is fabbed up some no door day mirrors. It's supposed to be like 78 and sunny on friday...
I'm jacking my own thread but does anyone have a "no weld" footpeg design?
like nerf bars or whatever theyre called?
Discussion Starter #19
no i am looking for the footrest that attaches to the bottom hinge for the door. so i can rest my foot on it outside. no wthat i have a little time to kill, i'll do a search for it, unless anyone has one... i'd post a pic but i don't have enough posts yet.
1 - 20 of 25 Posts
