1 - 16 of 16 Posts
personal opinion, if you wheel a lot, get the AR, if you dont plan on wheeling much, get the non disco bar ones like linked above. the added cost of a disco just doesnt make sense to me when all you are really doing is pulling a pin instead of removing a bolt. to me, that isnt worth $100
x2 so I replaced the bolts for pins that cost $25:punk:
You can get adjustable links. Without disconnects you have to realize when you flex you suspension out your going to break links. All the sway bar does is keep the suspension tight when on the road when you go off road you have to take your sway bar out of the equation
1 - 16 of 16 Posts
