Top Image:
DG/WT & PK/YL is for the Brake Transmission Shifter Interlock Solenoid.
Other wire is not stock. Looks like speaker cable.
Bottom Image:
There is a bundle or wire in the background that is not stock.
Top Image:
Bottom Image:
Thank you for the reply. I should've noted it's a manual LJ. After posting this, I searched for the service manual and the connector looks like the Left Dome Lamp. The lights inside work fine though, so I'm not sure what it being disconnected means.
As for the black wire bundle you mention, I just went outside and it appears to head up to the soundbar. The previous owner put an aftermarket radio in, so it's likely tied to that.
Yup... I checked the manual too. It's not connected because don't have a Brake Shift Interlock Solenoid.
