So I was going through my new, to me, 2001 TJ and found this toggle and button on the sides of my OBD Port. I can only assume it must be some sort of kill switch but since I bought it from a dealer I don't have contact with the original owner to find out. Wires from both go into the wiring harness, under the dash. anyone seen these before?
I once had a used car with a toggle switch in the ash tray compartment. I eventually determined that it's function was to disable the brake lights. Why that feature was desired is still a mystery.
I had a small switch like that on my firewall that was to an alarm system. Trace the wires, pull the loom and find out. Not a fun project but its the only way you will find out what exactly it is.
Those are definitely for an alarm system.... valet switch and programming button
My guess a switch to disconnect the door button switches for when the doors are removed. I installed something similar to not need the spring clips or pulling the fuse, when I take the doors off I just flip the switch to turn off the interior lights disabling the door buttons.
It's non stock, only way to find out is to trace the wires. Guessing won't do it.
