I have a 97 tj 2.5 i had the idle issue and it kicked out a code for 2 injector misfires i gave it a tune up. Plugs cap rotor wires. It ran fine about an hour then poof the idle flutters and it stalls i also have to give it gas at a stop or it will stall while coasting to the stop sign no dash lights on yet either.
If you clean you iac that might help. I kept stalling when coming to a stop. After I cleaned it I had no problems
