Hiya folks:
Ok, I have a running issue. Friday, on way to work, stalled in road. Would turn over, but not fire and run. Till battery died.
Victim is 2005 TJ Sport 4.0 6spd.
Replaced battery as battery was 8 years old.
Stalled again about 10 miles later. Refired and ran rest of way to work.
Stopped at FLAPS (Friendly Local Auto Parts Store), There was a CEL showing, but scanner revealed no stored code.
Resorted to google search bringing me here.
Fuel pump approx 5 years old. Can hear it prime when turn key.
Spark plugs and coil packs approx 50k miles old (OEM Iridium with 100k mile service interval).
Replaced Crank Position Sensor and Cam Position Sensor in parking lot of store.
MAF was cleaned approx 2 years ago.
1/2 tank gas from a store that stays busy, so likely good gas.
After installing Cam and Crank Position sensors, fired up with no CEL, but stalled again about 2 miles down road. Will only fire and run for ~30 seconds before stalling again, and then will not restart for ~10 min.
Fuel and air filter not very old (maybe a year.
Fuel pump relay and fuel pump fuse check out.
Ignition switch actuator pin and electrical connection replaced approx 18 months ago.
Original PCM failed (#5 injector pot popped) so junk yard computer (VIN says I should have Security system with chipped key from factory, but my TJ does not have this and has non-chipped black key), from a same 05 TJ 4.0 6spd.
As soon as it stops raining, I will take NOID detectors outside am=nd make sure injectors are receiving pulses.
How to check fuel rail pressure? Pictures of a rig to do this would be appreciated.
How to check for signal to coils?
Other things to check?
Thanks,
Hoon
Thanks,
Hoon
