I have one of those factory installed navigation/HD/dvd/cd/radio touch-screen systems in my 2008 jku and today it stopped turning on....black screen only....sometimes it looked like it would try to turn on and flash the "UConnect" screen for a few seconds, then turn off again. The fuse is not blown. Anyone ever had this issue? Or know what I can try to fix it?
Krew Member
#1 throw it out the window
#2 use an iPod with headphones
#3 pay someone to fix it like everything else on the jku...
#4 try running a new ground, molar is famous for grounding their radios through the antenna, which screws up after a little while.
thanks for suggestion #4 :)
Radio and Navigation won't turn on
I was wondering if you ever found out what was wrong with your radio? Mine is doing the same thing. If I push the on button it will show me JEEP and then turn back off.
Sorry for late response...this has happened a couple times to me now.... I completely disconnect the battery and then reconnect...it resets everything and the radio starts working again
