1 - 11 of 11 Posts
Hi guys, my jk2011 sahara has a problem everytime my gas is near half my check engine light comes on. Any of you guys experience this? Btw the meter reading is kms not miles.
Do you have an OBD code reader? A CEL should throw a code.
When we scanned it egr valve apear but when i brought it to the car dealer it turned of and they say its battery. Will try to change gas cap
Gas cap didn't fix the problem its the egr
Which EGR Code did you get when you did the scan?. There are more than one.. Knowing which one might make it easier to help you...
P0401 - Egr System Performance
P0403 - Egr Solenoid Circuit
P0404 - Egr Position Sensor Rationality Open
P0405 - Egr Position Sensor Circuit Low
P0406 - Egr Position Sensor Circuit High
When I had the CEL on my 2011 several weeks ago for the EGR; it was the P0406 code that identified the problem.
Discussion Starter · #11 ·
Sory but didnt really know what kind of code appeared i ordered the egr from a friend in ca because we dont have it here when they replaced it the engine light never came back
1 - 11 of 11 Posts
