-short red goes to battery. remove fuse while installing. -long red goes to another 12v power source depending on how you want the lights to work, but can also be straight to battery. -the 2 longer wires in the black vinyl sheaths go to the light housings. -the 2 remaining black leads go to a ground. one is the very short lead coming from the relay, the other one comes from the connector that goes switch. -your switch is that pod looking thing so the instructions are wrong in saying a switch is not included.
Yea I took a meter to the harness and figured it out Sat. night, can't believe that they do not send any better instructions. Oh well thanks for the reply.
