1 - 9 of 9 Posts
We did Saran Wrap on Sunday and my rig went everywhere effortlessly. However, I took one of the harder lines and knocked my steering wheel out of whack. On the way home it was upside down.
Today, I wrenched on it to get the steering wheel back to right side up. I may have turned the cuff on the drag link the wrong way to get the steering wheel corrected though... Now, I have limited right turn radius.
Any one else had this problem? Would I just need to turn the cuff the other way?
Let me know.
:atomic:
I'm also pulling code C1219 - Steering Angle Sensor Erratic Performance which is clearly tied to the steering problem.
Sounds like you bent something pretty good....did you find any damage under there? Bent tie rod or drag link I suspect. Can you take a good, well lit, picture straight on and post it up?
And seriously...a steering angle sensor? These JK's have gone to far....:D
Most importantly, is the trail completely clear of snow?
The trail is 97% clear. The snow wasn't an issue though. The trails and rocks were a bit slick though. I'll get some pics posted ASAP.
Cool. I'm in Parker off of Hilltop Rd. and Merryvale Trail if you want to come over and have me take a look at it. I'll be wrenching on cars all day anyway.
I'm over in Castle Rock and would have taken you up on this had I seen it earlier.
I fixed the steering radius part. I had turned the cuff the wrong way. I thought the wheel hadn't turned that much so took the easy route which turned out to be wrong.
Now I have a new question. Is the pitman arm supposed to be straight back and forward with the two bolts in line or is the picture below okay?
Discussion Starter · #7 · (Edited)
Here's the drag link pic and a few other pics. The traction warning light hasn't come back on after a couple test drives so I cleared it and we'll see if it come back anytime soon.
I know the TJ pitman arms are slightly off center when the wheels are pointed straight. Not sure about JK's with their curved PA. I don't see anything that sticks out to me as bad damage although in the one pic it looks like the tie rod has a slight bend by the diff cover. Not sure if that is normal for a JK or if it is just the way the pic was taken.
The JK track bar is built that way. I didn't think I saw too much damage either but took it to the shop this morning and their replacing the upper and lower track bar and the drag link. I noticed oil from the rear differential in the garage this morning too so I'm having them fix the damage there too.
Time for new under Armour!
1 - 9 of 9 Posts
