Help! My 2.5L 87 yj has an idle speed of 2k and jumps up to 2.5k when I press brakes. Plus brakes really stiff hard to press now??? Wth is up??
After running your vacume pod should hold a vacume .should hear it by pulling off vacume line at booster.also there is a one way valve at that connection
Disconnect the Booster and plug the vac line going to it. run the engine and see that it now runs as normal, and brakes are still hard to work. That's A Bad Brake Booster!
This would be a good time to upgrade for better brakes if you use larger than stock tires, on mine that was 205/75/15s LOL
