Front wheels not turning? I jacked up the back and locked in 4low, the front axle is locked in and then? The front drive shaft don't turn? At all? The case lowers the gears in the rear? Shifts in 4+4 with no problem? Idk?
So with the jeep up in the air, transfer case in 4wd the front driveshaft will not turn?
First thing to do is make sure the transfer is engaged. Check the linkage.
