they are supposed to be almost flat and a little to the right. more detailed..
Driver side headlight should be pointing a tad down, and a tad to the right
Passenger headlight shoud be pointing a tad bit down, and a tad to the right, but more straight than the driver side.
The idea is that you can see the curb on the passenger side better at night (Suppose to right the passenger curb not the middle line) and so that you never blind another driver.
If you are aiming them yourselves, just pull up about 15-20 feet from a wall. Far enough where you are not right ontop of it, but close enough where you can still see the "circle beam." Next, aim both light where it looks to be perfectly flat and striahgt ahead, then go back and turn them 2-3 turns of the screw down and to the right. They should look almost flat and straight on the wall, but if you look at the lights and seat level they should not be pointing at yours eyes.
Or you could just go to any authorized state inspection station and have them machine aligned for like 20 bucks
have a good one... -Jason
