05 sport in the north DFW area.
The interior of my wifes jeep was extremely dirty so I decided to remove the carpet and interior plastics and clean them. Now I put everything back together and try to drive it but I get nothing. I did move the transfer case lever when the car was in park (auto trans) and off in order to remove the front half of the center console. when i removed the front half of center console, i lifted the gear indicator light, turned it 90 degrees, faced it down and then just lifted the front half of the center console. did the opposite to reinstall. transmission seems fine (I can shift)
it seems the transfer case is stuck in neutral. however, my 4wd indicator light is on. the jeep is currently on an incline (front higher than rear)
PLEASE help ASAP as she needs to drive her jeep to work on Monday
Thank you very much
Thank you very much
