This is correct.I want to confirm that it shares the same place as the hose for the wiper fluid goes through, is that correct? I didn't want to cut the grommet until I was sure that is where Spod intend it to go through. I guess I will look again tonight, I think that is the only place that I can send it through!
Thanks, I just needed that to ease the mind a bit, plus I was cold I and didn't want to make a mistake. Just walk away...and come back with the right info, THIS PLACE IS GREAT! :drinks:This is correct.
I fed a fish tape in the hole and used it to pull the cable through.
It had to go down the firewall inside that hole.
