Just bought this LJ and I'm trying to figure out what the PO did to it. There is no body lift on it. Does it look like there is a small suspension lift on it or did the PO keep the stock suspension and just put larger tires on. Thanks!
What size tires are on it too? Doesn't look like there is enough flex room for a lift, but measuring would give you the real answer.
If you look just inside one of the rear tires where the frame goes up over the rear axle and the
Jeep body meets the frame the stock distance there between the body and the frame is about
1/4". Anything more than that is the amount of body lift there is.
Is this measurement the same for an LJ or just a TJ?
Measure between the spring perches.
Stock is 12" front, 8" rear. Anything above that is lift.
X2...read this pdf file:
Looks stock with 31's to me, but as mentioned put a measuring tape on the springs and measure.
Mostly old school..!
Should be the same. If you think there's a body lift,take a picture of one of the side body mounts and post it up.
