Ok so here's my problem, I went to install my new kenwood stereo and the cage is too all, do I have to buy anything to make it fit? Thanks
There are kits that may help, check your local Walmart or some such. Worst case online there are all sorts of kits.
Or if you are resourceful, build a bracket out of flat stock. Cut the hole for the cage, then screw, rivet, glue, or what ever, that piece to the dash.
yeah you gotta buy a aftermarket deck bracket that will be made for your specific jeep and the deck your using it will make it fit like it was suppose to be there
