1 - 16 of 16 Posts
Did someone swap in a V6 in that YJ or is it the stock 4.2 inline 6 cylinder?
Stock it came with Dana 35 in the rear and a high pinion dana 30 in the front
Welcome to the Forum redbuddy,
Back out one page and look for this sticky. A better way to get help in the YJ Tech Forum
Read the first post or two then ask your question. We need more info before we can help. A few pics makes it much easier to figure out what you're looking for.
Good Luck, L.M.
driveaxle shafts
We are still confused.....
So, you have a Jeep without tires on because you missing the AXLES..
Or, you have the AXLES but no tires on because you're missing the AXLE SHAFTS, or, you have the AXLES with AXLES SHAFTS and tires on and you are missing the DRIVESHAFT what connects the AXLES to the transfer case.
Reactions: SoCalC101CJYJTJ
How about making it easier for all of us to understand. Take pictures of what your questioning and post them.
I am fairly adept at deciphering what the goal is (or at the very least following along), but I am certainly not seeing the big picture on this one! I have my suspicions, but it will be interesting to find out.
I'm thinking drivelines
Auto part Suspension part Suspension Subcompact car
And that would be a DRIVESHAFT.....
A motor vehicle's driveline consists of the parts of the powertrain excluding the engine. It is the portion of a vehicle, after the prime mover, that changes depending on whether a vehicle is front-wheel, rear-wheel, or four-wheel drive.
Either way, unless the OP can get much more adept at explaining his needs we aren't going to be able to help him
Don't trust Wikipedia for accurate information...
The driveline is responsible for turning your axles, and your axle is what rotates your wheels. The driveline is connected to the differential and transmission through a series of universal joints. A popular nickname for a driveline is driveshaft
What Wikipedia describes is the Drivetrain which includes the transmission, driveline, and differential(s)
I usually don't go to a posters profile to find out what he's talking about because there's a sticky at the top of the YJ tech forum and the same sticky at the top of the YJ general discussion forum that describes how to get good suggestions. I refer to this sticky in my #6 post.
I'm guessing that redbuddy is unfamiliar with either US English or automotive terminology. If that's the case, I'll go the extra mile to help if I can.
I went to his profile and the one pic there looks to be some sort of spring over lift. The pic shows tires, so perhaps he needs suggestions on what driveshaft to use.
Once he posts some pics, we should be able to help him.
Since his posts are around 2:00 a/m mountain time, he may be in another country.
Good Luck, L.M.
1 - 16 of 16 Posts
