Here's what I still need to do before I can go back on the trails:
Tighten front sway bar link mount (Can't be too hard, right? Just need to know what
Replace serpentine belt (David can show me how to do it)
Remove and replace radiator
Remove and replace front track bar
Power flush transmission
Adjust front band (have no clue what this is)
Service transfer case
Service both diffs
Remove and replace front and rear pinion shaft seal
Remove and replace spark plugs
Clean all fuel injections
Clean off air intake system idle air control system
Clean of all intake manifold runners top of all piston and intake valves
If I can do most of this on my own, without a garage, let me know with some instructions, if possible, or a link.
Thank you
