I ordered a cobra 29 that I am going to wire to my battery, I also ordered 18' CB coax cable, rugged ridge mount and firestik antenna.
I don't understand how I am supposed to attach the coax to the antenna? Clearly I must be missing a component?
There is an adapter that mounts to your antenna mount. The antenna screws into one end and the coax screws into the other. They can be found at any truckstop and possible Radio Shack.
First off, what coax cable did you order? The standard coax will screw onto the end of a stud. Firestik makes a coax with a Firering that will attatch to the stud differently.
