I have recently purchased a used hardtop for my Wrangler 2001 SE Soft-top. I was wondering rather than spend a fortune on a hardtop wiring kit, Has anyone figured out a way to wire in a switch and power for the rear wiper, wiper pump, and defroster?
Wiper pump would be a problem since it is a new bottle and pump that comes in the kit. Is it an early or late hard top?
Knows a couple things...
Also the defroster requires a relay. The wiring for the rear wiper and defroster is not trivial to do it right like to insure the defroster shuts off when the ignition is shut off. I'd spring for the wiring kit.
Can be done somewhat complicated and requires proper size larger wires for defroster and ground
Relay relay spot already in PDC
Timer for defroster already built into cluster
Also need switches (can get from XJ)
Hardtop connector from neon or Durango depending on year
Cut hole then insert rubber ring and add 2nd pump to washer tank
Rest is just patient careful wiring and if you cannot figure that out looking at factory wiring diagrams this may not be a good project for you
