Hi guys, so I'm working on putting a prorock 44 with dynatrac ball joins under my '13 jk and I'm trying to reinstall the steering knuckles. With the bottom so tight the knuckle doesn't want to turn I have a ~1/4 in gap at the top. Is this normal? Am I missing something?
thanks
tim
Thanks. Still hard to move and still that 1/4" gap at the top ball joint. I have not greased the joints yet so maybe that is the hard to move bit but the gap is what has me concerned.
thanks!
tim
Thanks. Still hard to move and still that 1/4" gap at the top ball joint. I have not greased the joints yet so maybe that is the hard to move bit but the gap is what has me concerned. thanks! tim
I just installed a new knuckle and had the same gap. Grease should close it up.
My concern is how hard they are to move.. Def not a good thing.
Commercial Member
You may need to get a ball joint press and get that ball joint down on the upper C better?!?!
Do you guys suggest to use some Anti-Seize on the mating surfaces where the ball joints press into?
Discussion Starter #7
Just spoke with Dynatrac and the gap and tightness are 100% normal for there ball joints. Looks like i panicked for nothing but THANKS to everyone for there support!
tim
