Okay so my the other day I was leaving work for lunch and my yj just shut off I cranked it back up it shut off again. Then it wouldn't crank up so on my tow home I figured I'd try pull starting it and it fires up and makes it home then I fixed a couple vacuum leaks thought that was the problem, wasn't... Then I crawled under and poked the wire coming out of the crank sensor and it almost shut off. So I changed it and now it just seems worst.. Any help would be much appreciated.
Is the wire the crank sensor plugs into good back to wherever. It may have an issue. Best I got.
